thread safe random number generation
may_ka
Hi all,
this code implements a random number generator class and test class. An object of the test class contains a pointer to an object of the random number class which can either be allocated individually or point to a global object. The number of objects created for the test class may be several thousand. The question is whether this code for random generation thread safe?:
module Mod_Ran
  Implicit None
  Private
  Type, Public :: Ran
    Integer, Private :: Error=0
    Integer(kind=8), allocatable :: Seed
    Character(:), allocatable :: CSMSG
    Type(VSL_STREAM_STATE), allocatable :: TSS
  contains
    Private
    Procedure, PAss, Public :: Init => SubInit
    Generic, Public :: GetUniform => SubGetUniformVector
  End type Ran
contains
  Subroutine SubInit(this)
    Implicit None
    CLass(Ran), Intent(InOut) :: this
    Integer(Kind=8) :: brng
    Brng=VSL_BRNG_MCG59 !1.20
    if(allocated(this%TSS)) Deallocate(this%TSS)
    Allocate(this%TSS)
    if(.not.allocated(this%ISSeed)) Then
      Allocate(this%Seed,source=12345)
    End if
    this%Error=vslnewstream(this%TSS,brng,this%Seed)
  End Subroutine SubInit
  Subroutine SubGetUniformvector(this,InOut,lb,rb)
    Implicit None
    Real(Kind=8), Intent(In) :: rb, lb
    Real(Kind=8), Intent(InOut) :: InOut(:)
    this%error=vdrnguniform(&
      &method=VSL_RNG_METHOD_UNIFORM_STD_ACCURATE,&
      &stream=this%TSS,&
      &n=size(InOUt,1),&
      &r=InOut,&
      &a=lb,&
      &b=rb)
  End Subroutine SubGetUniformVector
End module Ran
Module Mod_Type
  use Mod_Ran
  private
  Type, Public :: TT
    integer(kind=8), allocatable :: seed
    Type(Ran), Pointer :: TSR=>Null()
    Real(kind=8), allocatable :: tmp(:)
  contains
    Procedure, Pass :: fill => subFill
  End type TT
contains
  Subroutine SubFill(this)
    Implicit None
    real(kind=8) :: rsr
    Class(TT), Intent(InOut) :: this
    if(.not.allocated(this%tmp)) Then
      allocate(this%tmp(100))
    End if
    !!check whether a stream exists, if not create one
    if(.not.associated(this%tsr)) Then
      if(.not.allocated(this%Seed)) Then
        call random_number(rsr)
        allocate(this%seed,source=int(rsr*100000.0D0,kind=8))
      End if
      Allocate(this%tsr);Allocate(this%tsran%seed,source=this%Seed)
    End if
    call this%tsr%getuniform(inout=this%tmp,lb=0.0D0,rb=1.0D0)
  End Subroutine SubFill
End Module Mod_Type
Program Test
  use Mod_Type
  use Mod_Ran
  Implicit none
  Type(TT), allocatable :: TVT(:)
  Type(Ran), allocatable, Target :: TSR
  Integer :: i
  Allocate(TVT(10000))
  !!option 1: everybody gets its on stream
  !$OMP PARALLEL DO
  Do i=1,size(TVT)
    call tvt(i)%fill()
  End Do
  !$OMP END PARALLEL DO
  !!option 2: everybody uses the same stream
  Allocate(TSR); call TSR%init(800466)
  !$OMP PARALLEL DO PUBLIC(TSR)
  Do i=1,size(TVT)
    tvt(i)%TSR=>TSR
    call tvt(i)%fill()
  End Do
end Program Test
From what I understood from the MKL manual, option  1 should be thread safe, option 2 not (in terms of correlations). Is that right?
Thanks a lot
karl
Pavel_D_Intel1
Hello! While your options can be considered as thread-safe given the assumption that the first option relies on the atomic call to the generator we recommend standard parallelization techniques for use with Intel MKL RNGs such as • Skipping-ahead • Leapfrogging • Using different parameters set Please, see documentation for additional details: https://software.intel.com/en-us/mkl-vsnotes-independent-streams-leapfrogging-and-block-splitting Choice of the generator as well as parallelization technique are driven by the requirements of the application. Please, let us know, if it answers your question. Best regards, Pavel.
Nishimura__Koji
Hi, I am trying to implement a parallel Monte Carlo simulation using MKL random number generator. A test program for that looks like the following. This program runs but the speed is incredibly slow. (it's some 10 times slower than a single thread version by commenting out the #pragma line.) I guess in my program the way to initialize the RNG system is not good but I couldn't understand what is the correct use of the initializing functions. Does anyone give me an advice to improve this? Also, I have no idea how much the value for "nskip" should be and I could not find its correct value on the Intel's documents including vslnotes.pdf, because those documents only shows pseudo programs as examples and they don't mentions the actual values to be set. Thanks a lot in advance. #include #include #include "mkl_vsl.h" #define N 1000*1000 #define M 10 int main() { double *r; /* buffer for random numbers */ double s; /* average */ VSLStreamStatePtr stream; int i, j, status, nskip; nskip = 2*N; r = (double*) malloc(N*sizeof(double)); #pragma omp parallel for for( i=0; i, VSL_BRNG_MCG59, 777 ); status = vslSkipAheadStream( stream, i*nskip ); vdRngGaussian( VSL_RNG_METHOD_GAUSSIAN_ICDF, stream, N, r, 0.0, 1.0 ); s = 0.0; for ( j=0; j += r; printf("Sum is %.4lf\n", s); vslDeleteStream( &stream ); } free(r); return 0; }
