unexpected ?potrf subroutine failure
Yuna_D_
AHi,
I need to generate a gaussian correlated noise based on a covariance matrix with fortran. I am using spotrf subroutine to do the cholesky decomposition. However, the decomposition is always failed at a specific row of input matrix. As the reference indicates, it means the leading minors of that row is not positive definite. But previous work with the same data in matlab chol function shows that the matrix is positive definite.
This problem is killing me now. Can anyone help me get out of the swap ? Or just if there is a better way to generate correlated noise without getting involved in the covariance matrix.The code for generate the covariance matrix and cholesky decomposition is listed below. Thanks a lot!!
Program DensityRealization
Implicit None
Real::lc
Integer::std,cases,Layer_Num,i,j,CholFlag
Real,Allocatable,Dimension(:,:)::c,sigma,rhostd
Real,Allocatable,Dimension(:)::z,Rnd
REAL,Parameter::p3=38.2273
Layer_Num=13827
std=20
cases=500
Allocate(z(Layer_Num),c(Layer_Num,Layer_Num),sigma(Layer_Num,Layer_Num),rhostd(Layer_Num,1),Rnd(cases*Layer_Num))
DO i=1,10000
    z(i)=(i-1)*0.01
 END DO
 DO i=10001,11799
    z(i)=100+(i-10000-1)*0.5
 END DO
 DO i=11800,Layer_Num
    z(i)=1000+(i-11799-1)
 END DO
! coveriance matrix
Do i=1,Layer_Num
  Do j=1,i
     c(i,j)=abs(z(i)-z(j))
     c(j,i)=c(i,j)
  End DO
End DO
c=-c/lc
c=exp(c)
rhostd(:,1)=std*exp(-z/p3)
sigma=matmul(rhostd,TRANSPOSE(rhostd))
sigma=sigma*c
!cholesky decomposition
CALL SPOTRF('U',Layer_Num,sigma,Layer_Num,CholFlag)
print*,CholFlag
End
mecej4
Please post the actual code. You cannot use the integer variable "Layer_Num" to dimension arrays, so your code gets rejected by the compiler. It is of little use to discuss the running behavior of code that cannot even be compiled.
It would be better if you attached the source file or pasted the code using the {code} button.
Yuna_D_
Sorry, I have modified the code. It should work now. Initially, it is just a subroutine in a big project, I extract the related code so it looks like this. Sorry for the trouble.
