use MKL_DFTI
Bo_Q_
I am having some problem in using the FFT routines within intel parallel studio 2013. I have read the following thread:
https://software.intel.com/en-us/forums/topic/296125
I copied mkl_dfti.f90 to my project directory and used "ifort -c mkl_dfti.f90" to compile the source code. The compilation generated two mod files. Up to this point, everything worked fine. But when I try to compile my code which calls FFT routines, there are errors saying:
Error    1     error #6284: There is no matching specific function for this generic function reference.   [DFTICREATEDESCRIPTOR]    C:\Users\m066760\Dropbox\fortran test\doFFT\doFFT\DOFFT.for    31
Could anyone shine some light on me? Thanks!
The source code for the project is attached.
Bo
mecej4
I do not see any error messages when I build the application using IFort 14.0.2. If I had a valid file called INPUT.TXT, I suppose the program would run, as well.
Please let us know the compiler and MKL version numbers, target architecture and OS version.
Bo_Q_
Thanks. I missed adding some lib files. Now it works.
