vector array in mkl
saar_w_
 Hi does anyone know what is the best mapping in MKL for  ippmMul_vaca_64f.
Saar.
Ying_H_Intel
Hi Saar,
I guess, you have known that ippm was deprecated in latest IPP version, and the replacement may be in MKL BLAS function or VSL functions.
https://software.intel.com/en-us/articles/the-alternatives-for-intel-ipp-legacy-small-matrices-domain
No sure what is your array layout, next operation, the vector size, machine type etc.  You may search in MKL reference machine,  there are a few of function be able to do  scalar * vector
for example, cblas_dscal()
The ?scal routines perform a vector operation defined as x = a*x
where: a is a scalar, x is an n-element vector
The ?axpy routines perform a vector-vector operation defined as
y := a*x + y
VSL functions: vdLinearFrac( n, a, b, scalea, shifta, scaleb, shiftb, y ) ,  y=(scalea·a+shifta)/(scaleb·b+shiftb), i=1,2 … n
or you create a matrix * vector according your vector array etc. Which usually have better performance.
Ying
saar_w_
Hi Ying and thank you for your quick replay ,
I am familiar with cblas functions but my problem is very specific for batch operation
the method ippmMul_vaca_64f is multiuplyng array of vectors with array of scalar ,
just like calling mutipale times to ?axpy. the difference is that it multiply all the vectors multi threaded and at once. how can I get the same result in MKL?
Ying H. (Intel) wrote:
Hi Saar,
https://software.intel.com/en-us/articles/the-alternatives-for-intel-ipp...
y := a*x + y
Ying
Ying_H_Intel
Hi Saar,
Right, current MKL only provide dgemm's batch function, no others, Do you have following operation after you get aX1, bX2, cX3, ... (a,b,c are constant number, XI is vector, how was the length and number of your vector array ?).  If no, it seems you have to call one blas function several times. or  you may add OpenMP progam  to parallel the calls.
Ying
