7287 Discussions
virus in 11.1\\054\\mkl\\ia32\\lib\\mkl_core.lib ?
kornic
I've recently run into trouble debugging Intel c++ compiler code generated under Visual Studio 2008.
The debugger will simply crash, where it didn't use... with memory acces violation.
BTWthe program works fine as long as I don't try to debug it!
Running a virus check (DrWeb), I'm getting "infected element within mkl\\ia32\\lib archive, more precisely:
C:\\Program Files\\Intel\\Compiler\\11.1\\054\\mkl\\ia32\\lib\\mkl_core.lib ...
Is there any problem already raised on this issue ?
Gennady_F_Intel
Quoting kornic
C:\Program Files\Intel\Compiler\11.1\054\mkl\ia32\lib\mkl_core.lib ...
kornic,
Thanks for letting us know. This is an unknown problem for today. It may be the false positive, but we will check with DrWeb. We encountered with the similar problem some time ago and it was the false positives. McAfee (v3.6) doesn't show the problem with these binaries.
--Gennady
Gennady_F_Intel
Hello all,
We checked this problem with DrWeb and they confirmed that this is false positive and DrWeb is going to fix the problems asap.
Regards, Gennady
Gennady_F_Intel
... for whom who are interested, DrWeb didn't confirmed only that it was the problem on their side but has been already fixed the problem and the fix is available on DrWeb site.
--Gennady
