why ifort cant find files which exist.
guayigou
it may be errors from link.i dont understand the cause.Factly,the files reported exist in the correct folder.
why?
thanks.
the report to errors:
ifort: error #10236: File not found: '/opt/intel/Compiler/11.0/059/mkl/lib/em64t/libmkl_blacs95_lp64.a'
ifort: error #10236: File not found: '/opt/intel/Compiler/11.0/059/mkl/lib/em64t/libmkl_solver_lp64.a'
ifort: error #10236: File not found: '/opt/intel/Compiler/11.0/059/mkl/lib/em64t/libmkl_lapack95_lp64.a'
ifort: error #10236: File not found: '/opt/intel/Compiler/11.0/059/mkl/lib/em64t/libmkl_intel_lp64.a'
ifort: error #10236: File not found: '/opt/intel/Compiler/11.0/059/mkl/../lib/intel64/libguide.a'
make: *** [driver] error 1
TimP
2 before linking the application please use mklvarsem64t.sh script (/tools/environment/) to set all libraries and compilers environment variables
Into your shell....
source /opt/intel/Compiler/11.0/059/bin/ifortvars.sh intel64 (.csh if running tcsh) sets the mklvars as well as the ifort environment. The MKL libraries are an optional part of the ifort install script.
You may have to find the make command to set up lapack95 inside the ifort mkl installation directory, if that is not an automatic part of the installation of your ifort version.
Gennady_F_Intel
Quoting - guayigou
why?
thanks.
Guayigou
1 - you would likely need to consult the link advisor on the right side of the forum header page
Into your shell....
TimP
Into your shell....
guayigou
Quoting - tim18
Thank you very much.
