7302 Discussions
ztrsm crashes on some inputs with the debug flags
ansobolev
I've experienced an issue when ztrsm crashes on some inputs with `-fpe0` flag enabled, while dtrsm does not. The inputs to both subroutines are the same up to the zero complex part. Without `-fpe0` flag the outputs of ztrsm and dtrsm are the same, as they should be.
This happens with 2025.3.2, 2025.3.0 and 2024.2.1, which are the versions I have access to. Can you please check? The MWE with the inputs is attached below. The two Fortran files that are in the archive can be compiled with
ifx -qmkl -O0 -fpe0 -o run_ztrsm_cplx run_ztrsm_cplx.f90
ifx -qmkl -O0 -fpe0 -o run_ztrsm_real run_ztrsm_real.f90
Thanks in advance!
Fengrui
This issue has been fixed. The fix will be included in the upcoming 2026.0 release.
Thanks again for reporting this issue!
Fengrui
Hi, thanks for reporting this issue in the forum!
I can reproduce this issue with the AVX2 code path while the AVX512 code path seems fine with the 2025.3 release. It is a regression since the 2024.2 release. We are actively working on this issue. Will update here once we get it fixed.
Thanks!
Fengrui
Fengrui
