I have implemented (tried to) a concurrent list as an exercise about mutexes.
I would like your feedback about it: if I used the mutexes correctly, if the mutexes should be better placed at another place, if I fotgot to use a mutex somewhere and any other advice you would be willing to provide.
Also, I would like your help about two topics.
The first one is the list destructor. I couldn't get it to work(I provide the commented code of the last thing I tried).
The second one is the InsertBefore function. This one inserts a new node before an existing one(since I haven't implemented any iterators for the list, I use the value of a node to search the place where the new one will be inserted). This function works well the first time I use it in main, however, the second time, it segfaults(the second call is commented in main).
Thanks!
[cpp]#include
#include
#include "tbb/atomic.h"
#include "tbb/blocked_range.h"
#include "tbb/parallel_for.h"
#include "tbb/partitioner.h"
#include "tbb/queuing_mutex.h"
#include "tbb/spin_rw_mutex.h"
typedef tbb::spin_rw_mutex ListMutexType;
typedef tbb::spin_rw_mutex NodeMutexType;
typedef tbb::queuing_mutex IOMutexType;
class EmptyListException: public std::exception {
private:
std::string M;
public:
EmptyListException(void):std::exception(){
M = "Empty List";
virtual ~EmptyListException(void) throw() {}
const std::string& What(void) const { return M; }
template
class Node {
template friend class List;
private:
T value;
Node* left;
Node* right;
mutable NodeMutexType NodeMutex;
public:
static const T max_val;
public:
Node(void):value(max_val),left(0),right(0){
NodeMutex = NodeMutexType();
Node(const T& v):value(v),left(0),right(0){
Node(const T& v, Node* l, Node* r):value(v),left(l),right{
~Node(void) {
NodeMutexType::scoped_lock lock( NodeMutex, true );
right = 0;
left = 0;
delete right;
delete left;
int& Value(void) {
NodeMutexType::scoped_lock lock( NodeMutex, false );
return value;
int Value(void) const {
return value;
template
const T Node::max_val = std::numeric_limits::max();
template
class List {
private:
Node* head;
Node* tail;
tbb::atomic size;
mutable ListMutexType ListMutex;
public:
List(void):size(){
head = new Node();
tail = new Node();
head->right = tail;
tail->left = head;
ListMutex = ListMutexType();
// ~List(void) { // THIS IS BEYOND ME
// ListMutexType::scoped_lock lock( ListMutex, true );
// if( Empty() ) {
// delete head;
// delete tail;
// else {
// Node* aux = head;
// Node* next = head->right;
// while( next != tail ) {
// delete aux;
// --size;
// aux = next;
// ++next;
// delete next;
// delete aux;
bool Empty(void) const {
ListMutexType::scoped_lock lock( ListMutex, false );
if( head->right == tail ) return true;
else return false;
const tbb::atomic& Size(void) const {
return size;
const T& InsertFirst( Node* node ) {
Node* aux(0);
NodeMutexType::scoped_lock lockhead( head->NodeMutex, true );
aux = head->right;
head->right = node;
node->left = head;
} // end lockhead
NodeMutexType::scoped_lock locknext( aux->NodeMutex, true );
node->right = aux;
aux->left = node;
++size;
aux = 0;
delete aux;
return node->value;
const T& InsertBefore( Node* node, const T& val ) {
if( Empty() ) {
head->right = node;
node->left = head;
} //end lockhead
NodeMutexType::scoped_lock locktail( tail->NodeMutex, true );
node->right = tail;
tail->left = node;
} //end locktail
} else {
Node* it(0);
ListMutexType::scoped_lock locklist;
locklist.acquire( ListMutex, false );
it = head;
while( it->value != val && it != tail ) {
++it;
locklist.release();
Node* aux(0);
if( it == tail ) {
aux = tail->left;
tail->left = node;
node->right = tail;
NodeMutexType::scoped_lock lockaux( aux->NodeMutex, true );
aux->right = node;
node->left = aux;
} else {
aux = it->left;
NodeMutexType::scoped_lock lockit( it->NodeMutex, true );
it->left = node;
node->right = it;
aux->right = node;
node->left = aux;
} // end else
it = 0;
delete it;
aux = 0;
delete aux;
}// end outer else
++size;
return node->value;
int RemoveLast(void) {
if( Empty() ) throw EmptyListException();
T toret( Node::max_val );
Node* aux(0);
NodeMutexType::scoped_lock lockend( tail->NodeMutex, true );
aux = tail->left;
NodeMutexType::scoped_lock lockprevious( aux->NodeMutex, true );
toret = aux->value;
aux->left->right = aux->right;
tail->left = aux->left;
delete aux;
--size;
return toret;
template
class ConcurrentBody {
private:
List* myl;
static IOMutexType IOMutex;
public:
ConcurrentBody(List* l):myl(l){}
~ConcurrentBody(void){ myl = 0; delete myl; }
void operator()(const tbb::blocked_range& r)const{
unsigned int val(0);
for( unsigned int i(r.begin());i!=r.end();++i){
if( i%2 == 0 ) {
val = myl->InsertFirst( new Node(i) );
IOMutexType::scoped_lock lock( IOMutex );
std::cout << "Inserted " << val << "\n";
} else {
val = myl->RemoveLast();
std::cout << "Removed " << val << "\n";
template
IOMutexType ConcurrentBody::IOMutex = IOMutexType();
int main(int argv, char* argc[]) {
List l;
std::cout << l.Empty() << std::endl;
try {
std::cout << "Inserted " << l.InsertFirst( new Node(7) ) << "\n";
std::cout << "Is empty: " << l.Empty() << " & size: " << l.Size() << std::endl;
std::cout << "Inserted before 7: " << l.InsertBefore( new Node(99), 7 ) << " & size: " << l.Size() << std::endl; //THIS GOES WELL
// std::cout << "Inserted before 99: " << l.InsertBefore( new Node(100), 99 ) << " & size: " << l.Size() << std::endl; // THIS SEGFAULTS
tbb::parallel_for(tbb::blocked_range(0,8),ConcurrentBody(&l),tbb::auto_partitioner());
} catch ( const EmptyListException& e ) {
std::cerr << "This happened: " << e.What() << "\n";
catch( const std::exception& e ) {
std::cerr << "Oops: " << e.what() << std::endl;
catch( ... ) {
std::cerr << "Unexpected\n";
return 0;
}[/cpp]
