Licensing Question
zach_turner
Supposing I have purchased a commercial license of TBB, is it acceptable for me to download the source aligned with this release, rebuild it, and then use this version in a commercial product?
Anton_Pegushin
New Contributor II
Quoting - zach.turner
one thing I know I can tell you is that there is no connection between open-source TBB licensing (which is a GPL v2 with runtime exception) and commercial TBB licensing. So if you want to modify the code of the open-source version of the library and then use it in your commercial product, your legal department has to OK it first.
