2467 Discussions
graph intermittently stalls with tbb::flow::async_node
Marc_R_5
It is either all or nothing.
Running  tbb43_20150611oss/src/test/test_async_node.cpp  reproduce the issue.  Either the test will run to completion or will never complete.   When the worker thread calls async_try_put() it does not always wake up the next node connected to it.
platform: linux_armv7_gcc_cc4.8_libc2.19_kernel3.10.40_debug
tbb: tbb43_20150611oss
Vladimir_P_1234567890
Hello Marc,
how many core you are running the test on?
--Vladimir
Marc_R_5
Hello Vladimir,
Good question!  I was running the test with only 1 core active.  Running the same test with 4 cores did not reproduce the stall issue.
Marc
