Intel vPro® Platform
3064 Discussions
AD Integration broken after KB5008102
SysArch
Hello
After the installation the security patch KB5008102 on our Domain Controllers, the AD integration is broken:
The security account manager blocked a non-administrator from creating or renaming a computer account using an invalid sAMAccountName. sAMAccountName on computer accounts must end with a single trailing $ sign.
Attempted sAMAccountName: xxxxxxxxx$iME
Recommended sAMAccountName: xxxxxxxxx$iME$
Link to the Microsoft KB: https://support.microsoft.com/en-gb/topic/kb5008102-active-directory-security-accounts-manager-hardening-changes-cve-2021-42278-5975b463-4c95-45e1-831a-d120004e258e
Unfortunately, uninstalling the security patch is not an option.
SergioS_Intel
Hello somersetchris,
We are following your case and would like to know if you need more assistance or we can close this thread.
Sergio S.
somersetchris
Hi Sergio,
Unfortunately there would appear to be some missing components from the release, specifically the Util's folder.
This contains the SCSEncryption.exe required to decrypt the profiles.xml file.
Encryption has changed in release 12, meaning a compatible version is needed to decrypt the new profile and manually edit the file to switch User Consent Off.
Chris
Mr_vPro
Chris,
Intel SCSEncryption.exe  tool was always part of Full SCS SW download package (one including RCS server installer) not part of SCS Wizard/Configurator package.
If you still have your Intel SCS 11.x full download package (80+ MB size) use version 11.x of SCSEncryption.exe tool from /Utils folder to decrypt your AMT Profile XML file (with password you used to save it) to clear text XML file and then open this file with Intel SCS 12.2.0.163 Configurator -ACUWizard tool to edit/modify it if needed and save into new XML file name. It will be encrypted with new algorithm  and password of your choice.
If you do not have Intel SCS 11.x download package  find  SCSEncryption.exe tool version 12.2 zipped -attached.
rgds
Dariusz Wittek
Biz Client Technical Sales Specialist  |  Intel EMEA CCG Technical Sales
somersetchris
Hi Dariusz,
Thank you for the SCSEncryption tool.
That has successfully decrypted the v12 profile .xml file.
Many thanks for your help.
Chris
SergioS_Intel
We are sorry to read about this inconvenience, please allow us more time to research on your issue.
Sergio S.
SergioS_Intel
We are following your question and would like to know if you need more assistance or we can close this thread.
Sergio S.
SergioS_Intel
Sergio S.
SergioS_Intel
We are following up on this case that is still open with the issue about the AD Integration broken after KB5008102.
We know that this is important for you to be resolved, and it is also equally important for us to get you the right solution. Since we have not seen an update for several days, we will temporarily close this case within 2 business days.
You can still reopen the case by replying to this email. Please note that your response is made more than 15 days after closing, a new case will be created with reference to the original case.
Sergio S.
SergioS_Intel
Hello SysArch,
We would like to inform you that we are going to close this thread.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
