Intel vPro® Platform
3072 Discussions
AMT Provisioning with cert in Admin Control mode not successfull
wosat666
Hello
we install the EMA server new on a standalone server
we want to activate the AMT with Admin Control mode
we purchase a cert together with the Certifikate responsible in the company
we config the EMA server and deploy the agent but we only see AMT status: Pending Activation
i use the tool emaconfigtool.exe and this is the output
see attach file
how can i find the problem?
Arun_Intel1
Hi wosat666,
Greetings!
We appreciate you sharing all the details including the ECT logs,
As per your query we see that you are trying to provision the Endpoint in the ACM, which is unsuccessful.
For the ACM, we have two criteria's that needs to be met.
First the Certificate, which has been provisioned successfully
The second is to configure the PKI DNS Suffix in the MEBx.
Please find the article given below to configure the PKI DNS Suffix in the MEBx, and follow, once done, kindly share your observation.
https://www.intel.com/content/www/us/en/support/articles/000058945/software/manageability-products.html
Best Regards
Arun_intel
wosat666
Hello Arun
which details and what is ECT logs?
i want to provision only devices in ACM which are connected by LAN
our WLAN device are provisioned by Client control mode and it is successfull
i use the Intel SCS service the last 20 years and only provision LAN devices in Admin control Mode
now i have some problems with the renewing of the cert and our SCS server
now i install the Intel Ema server and i was happy with the new feature to provision WLAN devices in CCM
and use the EMA Agent to deploy it
in the past i provision the device in ADM with following command
acuconfig.exe /verbose /output file c:\soft\ACU_Configurator\activate.log configviarcsonly vpro.hugoboss.com HBAMT /wmiuser hugoboss\sa_vpro /wmiuserpassword ***
i want to activate AMT in ACM remote by our software deployment
to activate our WLAN device in CCM is only necessary to install the EMA Agent with the config file
what is the process to activate the LAN connected devices in Admin Control Mode.
i create the EMAAgent.msh for Provisioning the device and use this in the installation of the EMAAgent
please explain me which information do you need to help me
thanks
Arun_Intel1
Hi wosat666,
Thank you for the detailed explanation.
We just appreciated you for sharing the details already, the AMT log that you have mentioned is the ECT log (EMA Configuration Tool)
As informed the SCS has reached the end of support.
To provision the AMT of the Endpoint to the Intel EMA console in ACM mode, as mention we do require two things here,
1) To successfully configure the Certificates which you have already done.
2) To Configure the PKI DNS Suffix in the MEBx, which we have to get it done now, please find the article link shared below and follow the same, once done, then generate the Intel EMA Agent files and provision the Endpoint's AMT, which should work fine.
https://www.intel.com/content/www/us/en/support/articles/000058945.html
Please feel free to reply for any further assistance.
Best Regards
Arun_intel
wosat666
hello Arun
i go to the MEBx and set the DNS Suffix hugoboss.com
no success
the log from the ema agent is
EMA Server DNS lookup failed: vpro.hugoboss.com is not known
but ping and nslookup on the client give me an answer
Arun_Intel1
Hi wosat666,
Greetings!
Thank you for sharing your observation, for us to further troubleshoot, we would require the Intel EMA server logs:
Please share the Swarm Server logs and the Manageability Server logs so that we can analyze and share our findings:
Steps to collect the EMA logs from the Server
Default Path:[System Drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
Please send me the files without the date called:
EMAlog-Swarmserver.txt
EMAlog-Manageabilityserver.txt
Best Regards
Arun_Intel
wosat666
Hello Arun
the client name is HBMEC033I
i restart the EMA Agent 16:32
i saw the error
Warning:Failed to push activation certificate - CERT_VERIFY_FAILED : (HBMEC033I,B9980147).
what is wrong withe the cert?
Arun_Intel1
Hi wosat666,
Greetings!
We see that the issue with the remote provisioning has failed as the certificate was created with the EMA FQDN and it needs to be with the domain of the company hugoboss.com
If you are configuring the Endpoint in ACM with wireless, then the certificate domain must also be added in the PKI DNS suffix of MEBx.
Please contact your certificate vendor and inform the same about the domain.
Best Regards
Arun_intel
wosat666
Hello Arun
i have a meeting with our Certificate responsible in the company
they do not under stand what is to change in our cert
please give me a detailed information how we create a cert
i upload you some pics of our cert
and we try to create a csr which was in the installation docu under 2.2.2 Additional Server Installation
but when i start the EMA Installer as Admin and choose install or update
i get an error that an older or same version was installed
thanks
Arun_Intel1
Hi wosat666,
Greetings!
Thank you for sharing the pictures of the certificates,
Please inform the certificate team, mentioning that the certificate has been purchased in the name of vpro.hugoboss.com from Sectigo which is incorrect,
They have to purchase the certificate in the name of hugoboss.com informing the same to Sectigo.
Please feel free to reply for any further query!
Best Regards
Arun_intel
Arun_Intel1
Hi wosat666,
Greetings!
Thank you for contacting Intel, please feel free for any further queries!
Best Regards
Arun_intel
wosat666
Hello Arun
can you delete my attachment pictures in this post
there are to many information about the company
thanks
Arun_Intel1
Hi wosat666,
Greetings!
Sure,
We will check and get the details deleted from the community post, and keep you posted.
Please confirm if your query has been answered.
Best Regards
Arun_intel
Arun_Intel1
Hi wosat666,
Greetings!
We have deleted the logs and pictures which had sensitive information.
Kindly check and acknowledge the same.
Best Regards
Arun_intel
Arun_Intel1
Hi wosat666,
Greetings!
Thank you for contacting Intel!
Feel free to revert for any further query!
Best Regards
Arun_intel
