Intel vPro® Platform
AMT issue
Minus6
Hello Team
I installed ACUconfig and tried to disable User Consent through Configure via Windows but this option wasnt there to change.
I tried to unconfigure it but as per your answer in another topic this puts me straight to CCM.
As this machine is 3h drive now from our office it would be problemtic to visit the site.
Is there a way for me to Configure via Windows and select Admin Control Mode and disable user consent?
Kind regards
Damian
MIGUEL_C_Intel
Hello, Damian,
Thank you for using Intel® AMT products.
ACUconfig is an old tool; Intel stopped supporting it, as well as Intel® SCS (software). Please tell us how you configured the endpoint.
If you configured the endpoint with Intel® EMA; the Intel® Endpoint Management Assistant (Intel® EMA) API Sample Scripts will work for you.
https://www.intel.com/content/www/us/en/download/19693/30076/intel-endpoint-management-assistant-intel-ema-api-sample-scripts.html
Miguel C.
Minus6
Hello Miguel
Thank you for your reply.
Previously when the device was in house we configured it through through the Bios I believe.
Dont think it was configured correctly as the device was installed on no-man site.
When we tried to use MeshCommander to remote in it was asking for the User Consent.
After doing my research I find our that I need to reconfigure it to Admin Control mode.
When I re-configure it its only come back to Client Mode again.
Thank you for the clarification about the ACUconfig, I wasnt aware.
Ideally I would like to get this on Admin Control mode and disable User Consent as it not fit for our purpose.
Would you recommend to use Intel® Endpoint Management Assistant to reconfigure it?
Do we need to go on site to reconfigure it?
Please let me know if you will have any questions.
Kind regards
Damian
MIGUEL_C_Intel
Hello, Damian,
Well, keep using Mesh Commander (third-party tool) or start using Intel® EMA depending on your endpoints’ specifications and company requirements.
Both tools support Client and Admin mode. You can configure the Admin mode by accessing MEBEX, in the User consent section select None and enable the IT option.
Intel® EMA requires the following:
Endpoints need to have Intel® AMT version 11.8.79 or higher.
It is necessary a host machine (virtual or physical) with Windows Server 2019 or 2022, SQL Server database.
Intel® EMA offers the remote provisioning of the endpoints (a Certificate purchase is necessary).
I am adding documentation with the requirements.
Intel® Endpoint Management Assistant (Intel® EMA) Server Installation and Maintenance Guide
https://www.intel.com/content/www/us/en/support/articles/000055629/software/manageability-products.html
Miguel C.
Minus6
Hello Miquel C
Thank you for coming back to me.
I cant find any information how to access MEBEX remotely.
Is this is something what we would need to be on site to do?
Kind regards
Damian
MIGUEL_C_Intel
Hello, Damian,
The MEBEX access requires to be on-site (physical access to the endpoint only).
Miguel C.
Minus6
Thank you Miguel.
Could you provide correct guide we should follow while being on site?
Once I will have all details I will schedule to visit the site an get everything sorted properly.
Kind regards
Damian
MIGUEL_C_Intel
Hello, Damian,
I am sending a zip file, that contains the pictures of an Intel® NUC.  They explain how to get to the user-consent section and disable it.
The presentation changes a little bit with the PC brand and version.
We access MEBEX with the hotkeys: Ctrl+P
In the User Consent section, set None for User Consent Opt-in
and enable Opt-in Configurable from Remote IT.
Finally, press Esc until the system shows the option to save changes.
Miguel C.
MIGUEL_C_Intel
Hello, Damian,
I am following up on your post.  Please let me know if I can help you with anything else.
Miguel C.
Minus6
Good morning Miquel
I hope you are well.
Thank you so much for your help.
We would need to visit the site at some point with your instructions.
I am more than happy for you to close this case now.
Kind regards
Damian
MIGUEL_C_Intel
Hello, Damian,
Thank you for your feedback.  Please do not hesitate to reply if further assistance is necessary.
Miguel C.
