Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3087 Discussions
About the Access Rights setting for User Groups
M_T11
In the EMA Management Console, I believe “Access Rights” can be set when creating “User Groups”. (as shown in the capture below).
What functions will be available by enabling this item?
vij1
Hello M_T11,
Greetings!
By enabling "Access Rights," you can customize these permissions to ensure that each user group has the appropriate level of access and control over the devices and functions in your EMA environment.
  1. Desktop Access: Users can remotely access and control desktop environments on managed endpoints.
  2. Terminal Access: This allows users to interact with command-line interfaces on the endpoints.
  3. Power Operations: Users can perform power management tasks, such as powering on, off, or rebooting endpoints.
  4. USB Redirection: This function enables users to redirect USB devices connected to their local machines to the remote endpoints.
Vijay N.
M_T11
Thank you for your response.
Looking at the items of the content you replied, it seems that there are only 4 items: [Desktop Access], [Terminal Access], [Power Operations], and [USB Redirection].
Excuse me, but could you explain some of the other items (for example, Endpoint Management)?
Best regards.
vij1
Hello 三浦,
Hardware Manageability Tab
Allows you to perform many out-of-band Intel® AMT operations. In order for this to work, Intel AMT must be configured by the current Intel® EMA instance. That is, endpoints configured by a different Intel® EMA instances cannot be operated on using this tab.
Please refer the below attached Intel® EMA Admin and Usage Guide section 6.3.2 to 6.3.7
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-admin-and-usage-guide.pdf#page=39
Vijay N.
vij1
Hello 貴 三浦,
Greetings!
I am following up on the case and wondering if I can help you with anything else. Look forward to your response.
Vijay N
vij1
Hello M_T11,
Greetings!
If further assistance is necessary, do not hesitate to reply.
Vijay N
M_T11
I checked sections 6.3.2 to 6.3.7 of the document you provided, but I cannot find any mention of Endpoint Management.
Could you please tell me what happens if I check the box in the red frame in the screenshot and if I don't?
M_T11
Hi vij1
Do you have any answers to the above?
