Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
Active Directory Integration
IBrow
Any tips on why my AD integration may be failing, or where to start looking / debugging?
Background:
RCS server deployed in database mode.
AD OU set up and permissioned.
Enterprise CA set up and template created and permissioned.
Profile created on the RCS
acuconfig.exe ConfigViaRCSOnly succeeds and provisions machine. Certificate is created by the CA, Computer object is created in the OU.
Logging on to https://127.0.01:16693/ https://127.0.01:16693/ works using Admin and the "Get configured Password" from the RCS
Logging on to https://127.0.01:16693/ https://127.0.01:16693/ fails for Domain accounts.
Am I missing something here? I assume this should work.
Provisioning command:
acuconfig.exe /Verbose /Output Console ConfigViaRCSOnly rcsserver.mydomain.com StandardLan /AbortOnFailure /ADOU OU=AMT,OU=Others,DC=mydomain,DC=com /RCSBusyRetryCount 5
Profile details (domain names changed for obvious reasons)
Profile Name: StandardLAN
Profile Type: Intel AMT
Network Settings
FQDN will be the same as the Primary DNS FQDN
IP will be taken from DHCP
Active Directory OU:OU=AMT,OU=Others,DC=mydomain,DC=com
Access Control List (ACL)
User 1: mydomain.com\AMTAdministrators
User Type: Active Directory
User has both remote and local access to the realms listed below
Realms: Redirection, PT Administration, Hardware Asset, Remote Control, Storage, Event Manager, Storage Administration, Agent Presence Local, Agent Presence Remote, Circuit Breaker, Network Time, General Info, Firmware Update, EIT, Local User Notification, Endpoint Access Control, Endpoint Access Control Administrator, Event Log Reader, User Access Control
Transport Layer Security (TLS)
Server authentication used for remote interface
Server Authentication Certificate Properties:
Certificate Authority: ca-cert-001.mydomain.com\MYDOMAIN-ISSUING-CA-001
Certificate Template: AMTWebServerCertificate
Common Names (CNs) in certificate: DNS Host Name (FQDN), Host Name, SAM Account Name, User Principal Name, UUID
Network Configuration
WiFi
Do not enable synchronization of Intel® AMT with host platform WiFi profiles
System Settings
Enabled Management Interfaces:
Web UI
Serial Over LAN
IDE Redirection
KVM
RFB password not defined
Power Management Settings: Always On (S0-S5), Timeout if idle: 3 minutes
The Intel® AMT clock will be synchronized with the operating system clock
Intel® AMT will not respond to ping requests
Fast Call for Help (within the enterprise network) is Enabled
MichaelA_Intel
Halibut
Hi Halibut,
I'm going to assume you're using Internet Explorer. For kerberos authentication, there is a setting in IE that needs to be changed:
In the advanced tab of IE>internet options, there is a check box for "Enable Integrated Windows Authentication". Checked is kerberos, unchecked is digest.
You will also need to perform the following registry edits:
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_INCLUDE_PORT_IN_SPN_KB908209] "iexplore.exe"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_INCLUDE_PORT_IN_SPN_KB908209] "iexplore.exe"=dword:00000001
Michael
MichaelA_Intel
Halibut
Hi Halibut,
Michael
IBrow
Gah!
Well that was a day of my life I wont get back. Than you very much Michael, it's working now, as it apparently had been all along. The keys in IE were all it needed.
I.
