Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
CIRA Not Connected
N0
I have an Intel® EMA v1.12.1.0 server and have successfully provisioned an endpoint in Admin Control Mode with a PKI certificate.
The AMT Profile has the following configurations :
- General : Always Use Intel® AMT CIRA
- FQDN Source : Shared with host OS
- IP Address : From the DHCP Server
I try to have CIRA connect but still can't after following the troubleshooting guide here :
https://www.intel.com/content/www/us/en/support/articles/000059019/software/manageability-products.html
Here is the EMA Configuration Tool output from the endpoint :
Intel EMA Configuration Tool
Application Version: 1.1.0.183
Scan Date: 2024-05-14 12:42:37
*** Host Computer Information ***
Computer Name: [REDACTED] (endpoint)
Manufacturer: HP
Model: HP ProDesk 600 G3 SFF
Processor: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
Windows Version: Microsoft Windows 11 Éducation
BIOS Version: P07 Ver. 02.46
UUID: 019B152B-15FF-FA7B-8903-581568888D0B
*** SMBIOS Information ***
AMT Supported: True
AMT Enabled: True
SMBIOS ME SKU: Intel(R) Standard Manageability
SMBIOS ME Version: 11.8.92.4222
KVM Supported: False
SOL Supported: True
USB-R supported in BIOS: True
RSE Supported: True
*** ME Information ***
State: Provisioned
Control Mode: Admin
Driver Installed: True
Driver Version: 2406.5.5.0
PKI DNS Suffix: Not Found
LMS State: Running
LMS Version: 2406.5.5.0
MicroLMS State: NotPresent
EHBC Enabled: False
*** ME Capabilities ***
AMT in Enterprise Mode: True
TLS Enabled: True
HW Crypto Enabled: True
Current Provisioning state: POST_PROVISIONING_STATE
NetworkInterface Enabled: True
SOL Enabled: True
IDER Enabled: True
FWUpdate Enabled: False
LinkIsUp state: True
KVM Enabled: False
RSE Enabled: False
*** Power Management Capabilities ***
Supported Power States:
5: PowerCycle_Off_Soft
8: Off_Soft
2: On
10: Master_Bus_Reset
11: NMI
7: Hibernate
12: Off_Soft_Graceful
14: MasterBusReset_Graceful
Power Change Capabilities:
2: On
3: SleepLight
4: SleepDeep
7: Hibernate
8: Off_Soft
*** CIRA Information ***
CIRA Server: Not Found
CIRA Connection Status: NOT_CONNECTED
CIRA Connection Trigger: USER_INITIATED
*** ME Wired Network Information ***
Wired Interface Enabled: True
Link Status: Up
IP Address: [REDACTED]
MAC Address: 40:B0:34:F8:0F:05
DHCP Enabled: True
DHCP Mode: Passive
DNS Suffix (from OS): [REDACTED] (sub.domain.org)
*** ME Wireless Network Information ***
ME Wireless Interface Not Detected
*** Root Certificate Hash Entries ***
[REDACTED]
I checked that all DNS suffixes match; the EMA server DNS name, the PKI certificate DNS suffix, DHCP option 15 and the endpoint DNS suffix all match.
For example :
EMA Server DNS : intel-ema.sub.domain.org
PKI Certificate : CN=intel-ema.sub.domain.org
DHCP option 15 : sub.domain.org
Endpoint FQDN : endpoint.sub.domain.org
I am a bit out of ideas as to what is blocking CIRA ...
MIGUEL_C_Intel
Hello, No,
I reviewed the specifications of the endpoint HP ProDesk 600 G3 Small Form Factor and found some of the following:
  • HP website is saying only Windows 7, 8, and 10; the lack of fully compatible drivers could be blocking the connection.
  • In addition, there is a higher BIOS revision available. It improves the connection and security.
   HP ProDesk 600 G3 Small Form Factor PC – BIOS version 00.02.49 Rev.A
   https://support.hp.com/us-en/drivers/hp-prodesk-600-g3-small-form-factor-pc/15292277
  1. Is the endpoint in the same domain as the EMA server?
  2. Please tell me about the certificate.  Is it a vPro Certificate from any of our Authorized vendors? The Root, intermediate, and leaf should be SHA256 or higher (Review it from IIS).
  3. In addition, please tell me about the OS of the server.  The endpoint is old and does not support the latest secure Cipher suites.  Use an IIS crypto software such as Nartac in the Server machine and enable at least TLS_RSA_with_AES_128_GCM_SHA256.
Look forward to your outcome and details.
Miguel C.
N0
Hi Miguel, thank you for your quick reply.
This is indeed an older PC that I use to test the the integration of our EMA server.
As suggested I have upgraded the BIOS version to : P07 Ver. 02.49
[...] the lack of fully compatible drivers could be blocking the connection.
I used HP software to check that drivers are up to date, let me know if there are additionnal verifications I can make to ensure this is not the source of the problem.
Yes they both are in the same domain and share the same DNS suffix ( e.g. *.sub.domain.org )
It is a vPro certificate issued by Sectigo (https://sectigostore.com/ssl-certificates/amt-certificate)
Intel EMA (Sectigo) certificate is SHA256 and the 2 above are SHA384.
The EMA server OS is Windows server 2022 standard ( Version 21H2 - Build 20348.2402 )
I will check to enable TLS_RSA_with_AES_128_GCM_SHA256 and report back.
MIGUEL_C_Intel
Hello, No,
I am following up on your post, please let me know if I can help you with anything else.
Miguel C.
N0
I have verified the server and TLS_RSA_WITH_AES_128_GCM_SHA256 is enabled and available.
Is there some client logs I can extract to debug this further ?
MIGUEL_C_Intel
Hello, No,
Nice to hear you again.
Yes, there are logs from the endpoint that we can gather.  In addition, please send me the Server logs (especially the Swarm and the Manageability logs).
EMA logs from the Server
Default Path: [System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
Please send me the files without the date called:
EMAlog-Webserver.txt
EMAlog-Swarmserver.txt
EMAlog-Manageabilityserver.txt
EMA log from the endpoint:
Default Path: [System drive]\Program Files\Intel\EMA Agent\EMAagentlog
Look forward to your answer.
Miguel C.
MIGUEL_C_Intel
Hello, No,
I hope you are doing well.
By any chance, have you been able to gather the Server and endpoint logs?
Miguel C.
N0
Hello Miguel,
Sorry for the delay, I have checked the server logs but there doesn't seem to be anything related in these, just a few unrelated lines that seems like normal operations.
And unfortunately there is no logs on the endpoint at the specified location.
MIGUEL_C_Intel
Hello, No,
Do you mind sending me via community or private message the server logs?
Look forward to hearing back from you.
Miguel C.
N0
EMALog-ManageabilityServer
2024-05-27 01:33:01.0667|INFO||9704|20|TimerCleanupElapsed - MeshManageabilityServer.CentralManageabilityServer, EMAManageabilityServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - [0] - Message:Performing database cleanup.
2024-05-27 05:33:00.0803|INFO||9704|22|TimerFileUploadCleanupElapsed - MeshManageabilityServer.CentralManageabilityServer, EMAManageabilityServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - [0] - Message:Performing orphan files cleanup.
2024-05-27 05:33:02.5650|INFO||9704|10|TimerCleanupElapsed - MeshManageabilityServer.CentralManageabilityServer, EMAManageabilityServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - [0] - Message:Performing database cleanup.
2024-05-27 09:33:04.0694|INFO||9704|29|TimerCleanupElapsed - MeshManageabilityServer.CentralManageabilityServer, EMAManageabilityServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - [0] - Message:Performing database cleanup.
EMALog-SwarmServer
2024-05-25 05:32:42.6987|INFO||9920|10|UpdateAgentStore - MeshServer.AgentVersionControl, EMASwarmServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - Pulled Agent: Type=2, Version=11200, Time=2024-02-01 4:39:36 PM, size=4217536
2024-05-25 05:32:45.9955|INFO||9920|10|UpdateAgentStore - MeshServer.AgentVersionControl, EMASwarmServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - Pulled Agent: Type=4, Version=11200, Time=2024-02-01 4:39:36 PM, size=4403904
2024-05-25 05:32:46.0893|INFO||9920|10|.ctor - MeshServer.CentralServer, EMASwarmServer, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: ServerStart, 1
2024-05-25 05:32:46.1361|INFO||9920|13|<RunReceivedMessageProcess>b__65_0 - MeshServersCommon.code.TcpStack.MessageManager, EMAServersCommon, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - Received ServerState for server type 1 id 1 with state STARTING.
2024-05-25 05:35:17.1560|INFO||9920|13|<RunReceivedMessageProcess>b__65_0 - MeshServersCommon.code.TcpStack.MessageManager, EMAServersCommon, Version=1.12.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - Received ServerState for server type 1 id 1 with state AGENT_START. Endpoint count is 1. Endpoint id list is DE2A04A28789936DF0AF667C97AD1FA3BD9A740B09242B48F36979214574E908.
EMALog-WebServer
2024-05-27 09:40:56.8806|INFO||9208|1|SetupBackendLogger - MeshWebCore.WebApi.WebApiConfig, EMAWebCore, Version=1.12.1.0, Culture=neutral, PublicKeyToken=null - EVENT: Information, Web API server is starting up.
MIGUEL_C_Intel
Hello, No,
Thank you for sharing the logs.
They are almost empty.  Please tell me about the database, which SQL version you are using, and location.  Also, tell me where Windows Server 2022 is installed.
Regarding the Certificate issue, we could set a web meeting; I will try to help you fix the SHA1 error.  Please send me a private message with your schedule availability.
Miguel C.
N0
The database is MSSQL Server 2022 version 16.0.4120.1 residing on the same Windows server as the EMA Server, and this windows server is installed in a virtual infrastructure on premise.
MIGUEL_C_Intel
Hi, No,
Thank you for your quick reply.
I reviewed the issue from scratch and the configuration looks good. I am wondering if you are open to setting up a web meeting. I want to review the certificate closely and try to resolve the issue.  I have availability tomorrow (5/29) at 12 PM US PST.
I am adding a summary of your environment, please let me know if something is wrong or missing.
Windows Server 2022 standard
Virtual machine with both
EMA 1.12.1.0
Admin Control Mode
Certificate: Sectigo
Remote Provisioning – DHCP DNS matches the EMA domain.
Endpoint in the same server domain: Yes
Pictures show 4 lines
It is showing the AAA as SHA1
Endpoint:
BIOS Version: P07 Ver. 02.46 (02.49)
Windows 11 (not supported as per HP website)
Wind 11
ME: 11.8.92.4222
LMS State: Running
Intel® Standard Manageability
State: Provisioned
Control Mode: Admin
Network: wired
I look forward to your reply.
Miguel C.
N0
Information looks good, I am available for a meeting tomorrow at that time.
MIGUEL_C_Intel
Hi, No,
I am going to send a private message with the invite.  See you soon.
Miguel C.
smaki
Hello N0,
Excuse me for cutting in.
I think the system is not a vPro platform.
Because it's manageability feature is Intel Standard Manageability (ISM) and not Intel Active Management Technology (AMT).
Your system:
State: Provisioned
Control Mode: Admin
LMS State: Running
EHBC Enabled: False
My sytem:
Version: 11.8.86.3877
SKU: Intel(R) Full AMT Manageability
State: Provisioned
Control Mode: Admin
Driver Version: 2145.1.42.0
PKI DNS Suffix: makky.org
LMS State: Running
LMS Version: 2145.1.42.0
EHBC Enabled: False
My system is not HP's PC, but it's the same generation platform.
I don't know why your PC isn't a vPro platform. You may need to talk with system vendor.
Only AMT has capability of CIRA function.
https://www.intel.com/content/www/us/en/support/articles/000090499/technologies/intel-active-management-technology-intel-amt.html
"Fast call for help" is older name. Now it is called as "Client Initiated Remote Access (CIRA)"
By the way, starting from Alder Lake platform, ISM also supports CIRA.
Thank you,
smaki
N0
Hello smaki,
Thank you for the info, that might explain why this specific feature was not available on this older model.
