Intel vPro® Platform
CVE-2017-5689
fungroy
Try to tackle the INTEL-SA-00075 issue (CVE-2017-5689). Currently using HP Z440. Already apply patch SP80050 according the the site and see the firmware are up from 9.1.37.1002 to 9.1.41.3024. However, still go the error message like this:
Risk Assessment
Based on the analysis performed by this tool, this system's Firmware has been updated and system is in unprovisioned state. See Explanation for specifics.
Explanation:
The detected firmware on this system has the fix for INTEL-SA-00075. Ensure that the INTEL-SA-00075 tools were used to perform a full unprovisioning of the system prior to reprovisioning. This will remove any unauthorized configuration settings.
I believe using the dectection tool already unprovision. I am not sure whether it had been provision before.
Before apply the patch:
CSME: The system is not supported.
Intel-SA-00075: The system is vulnerable
After apply patch:
CSEM: The system is not supported
Intel-SA-00075:
Explanation:
Also, what exactly is "Intel Active Management Technology, Intel Small Business Technology, and Intel Standard Manageability"? I might just as well disable it at all.
Any help is appreciate.
JoseH_Intel
Hello fungroy,
Thank you for joining the community
We will proceed to close this thread as per there is a case already opened with Intel where this issue is been addressed. We encourage you to continue working on the original ticket.
Jose A.
