Intel vPro® Platform
3051 Discussions
Connect to endpoint fails
Benjovy
Trying to setup EMA for the first time.  I've installed certificates etc..etc.. and followed installation guide.
Getting an error when I try connect to a test endpoint.
Websocket connection could not be established. The URL used in web browser may be different from Intel® EMA server URL specified at Intel® EMA installation time.
I do get a similar message when I log into the console but it seems to login regardless.
The current URL used in login does not match the URL entered in Intel® EMA Settings. Cross-origin requests may get blocked. The URL in settings is https://emaserver.domain.com.au
Help please!
Cheers
Ben
Victor_G_Intel
Hello Benjovy,
To continue we will need the information below:
  1. What exactly is the EMA version you are working with?
  2. Please provide the exact AMT version being used on the endpoint(s).
  3. Is the EMA server installed on a physical server or on a virtual machine?
  4. How many endpoints are you planning to have in your environment?
  5. Is the test endpoint you mentioned provisioned in CCM (client control mode) or ACM (Admin control mode)
  6. We will require a screenshot of both errors you get one while trying to log in to EMA and one while trying to connect to your test endpoint
  7. Additionally, we are going to need a picture/screenshot of the enhanced key usage and the certification path of your PKI, secure, and root certificates.
  8. The logs below will be required as well:
  • EMA logs from Server:
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
  • EMA log from the endpoint:
[System drive]\Program Files\Intel\EMA Agent\EMAagentlog
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello Benjovy,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello Benjovy,
We have not heard back from you.
Victor G.
