Intel vPro® Platform
3052 Discussions
DQ67SW: Can't activate Intel ME with initial password
Hi all,
I already searched for a solution but didn't find till now.
I've a DQ67SW Bios 0064 and try to activate Intel ME. Bios asks for password, but password "admin" doesn't work.
Jumper for Bios Maintenance was set and ME password reset was showed as successful.
But if I try to activate Intel ME and enter password "admin", it doesn't still work.
Does anyone has a hint what's happen here?
Thank you in advance for your support,
swrue
Joseph_O_Intel
The first thing I would do is check your processor and confirm that it is vPro enabled. I am able to confirm the board is vPro, but the processor needs to be as well.
Joe
Joseph_O_Intel
In order to rest your password for the MEBx.
All you need to do is unplug the system and removing the cmos battery for a few minutes. Then reassemble system and give it a try
