- Marcar como nuevo
 - Favorito
 - Suscribir
 - Silenciar
 - Suscribirse a un feed RSS
 - Resaltar
 - Imprimir
[Filter: smut] JMLooper's post body matched "xxx", board "vpro-platform".
Post Subject: Re: Endpoint gets locked after a few tries of starting a user consent session via API (ExtendedCode2
Post Body:
Hello Suneesh,
Thank you for your quick replies.
I have been given the logs of the day I did most of the testing (08-05-2025). What I've found are the following errors related to the endpoint I did my testing on:
- `The endpoint with ID: XXX is not reachable.`
- `Unexpected failure getting AMT platform capabilities of an endpoint XXX, Exception:System.NullReferenceException Object reference not set to an instance of an object. at MeshWebCore.WebApi.Models.Repositories.EndpointRepository.<GetEndpointAmtPlatformCapabilitiesAsync>d__14.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at MeshWebCore.WebApi.Controllers.EndpointsController.<GetAmtPlatformCapabilitiesById>d__14.MoveNext()`
They appear many times during the day. Unfortunately I have not been given direct access to the server yet, so I have not been able to do testing where I see the errors as they appear. I may be able to get this access in some weeks. In any case, there is no other type of error related to the endpoint I've been using to test.
In any case, I can't extract much more information from `The endpoint with ID: XXX is not reachable.` than from `Endpoint is not ready to execute this operation yet, please wait and retry`. Do you know what could be happening or where else could I have a look at?
Body text "XXX" matched filter pattern "xxx".
Post by User[id=438769,login=JMLooper] was rejected for the following end-user facing error(s):
- Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Enlace copiado
- Marcar como nuevo
 - Favorito
 - Suscribir
 - Silenciar
 - Resaltar
 - Imprimir
Hello JMLooper,
Thank you for your continued engagement.
We’ve noticed that each of your replies has created a new thread for the same issue. To keep the communication streamlined and ensure we’re addressing everything efficiently, we’ll proceed to close this thread and continue working with you on the active thread linked below:
Please feel free to continue posting updates or questions there. If further assistance is needed, we’re here to help.
Suneesh S
 - Marcar tema como nuevo
 - Marcar tema como leído
 - Favorito
 - Suscribir
