Intel vPro® Platform
2837 Discussions
Getting errors during Vpro configuration
kayas
I'm trying to test AMT on our corporate machines but i couldn't proceed although i've tested on two different hardware.
First of those is HP Z1 G2 with Windows 10 1909 x64. When I open Intel AMT Configuration Utility and proceed by clicking "Configure/Unconfigure This System" I get "Call to function failed with return code"
And the second is Dell XPS 15 with Windows 10 1909 64. This one I can proceed to the next screen. When I select configure via Windows, I get "This configuration option is not available because the system does not support host-based configuration"
These 2 errors may have different underlying issues but I'm stuck.
kayas
And, HP Z1 requires latest Intel management engine software.
All sorted now. Lessons learned:
  1. Check if the CPU is supported
  2. Check if you have latest version of Intel Management Engine Software is installed.
kayas
It seems Dell XPS doesn't come with vpro supported CPU, so this explains the issue with Dell XPS 15.
kayas
Jimmy_Wai_Intel
If you are sitting in front of a PC, the best to find out if it is a vPro PC is to look for the vPro sticker on the PC.
