Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Help with Intel(R) Management Engine Interface
Please forgive the this low level question. Hope you ca help me. I was running the compability software for Windows 7, when the results indicated that the Intel(R) Managemet Engine Interfance was NOT compatible. Can this be upgraded? Including system information.
Thank you
Jacob_G_Intel
This does not appear to be a vPro system nor does it appear to have AMT. Either way, I am not familiar with this system. I'd recomend asking Gateway if they have or plan to release a driver.
My general experience is that Vista Drivers for ME work fine in Win7, just set Vista Compatibility mode. Also, unless you have a reason to install the ME drivers, you don't really need them. I deal with many vPro systems that never load this driver, and the ME works just fine. However, a disclaimer...I have never worked with that system (or even any G33 based systems) so your milage may varry.
