Intel vPro® Platform
3065 Discussions
History of accesses to endpoints
Jiri2
Please advise me where to find the .log files or where to view the endpoint access history. When and who accessed the endpoints.
Thank you
Jiri
vij1
Hello Jiri2,
To retrieve audit logs/events from your Intel EMA server, you can use one of the following methods:
  1. Database Method:
  • Intel provides a sample PowerShell script for retrieving logs directly from the database.
  • You can download this script from Intel EMA API Sample Scripts.
  • After downloading, navigate to the Snippets directory in the downloaded file for the relevant script.
  1. API Method:
  • Access the API documentation via your EMA server at: https://your_ema_server_url/swagger.
  • Look for the AuditEvents API, which provides detailed instructions for retrieving audit logs.
  • Refer to the API samples in the download link above to understand how to interact with the EMA server through APIs.
Both methods offer flexibility depending on your preferred approach. Please let us know if you need further assistance with either method.
Vijay N
vij1
Hello Jiri2,
Greetings!!
I am following up on the case and wondering if I can help you with anything else. Look forward to your response.
Vijay N.
Suneesh
Hello Jiri,
Good day.
We are following up on this case. If further assistance is necessary, please do not hesitate to reply.
Suneesh S
intel.com/vpro
VitorRosa
Hello, Friends, I need some help to know if it is possible to have the name of who is trying to access the endpoint in the user consent request? If so, how do I do it? And if not, there must be some simple way to know who accessed the endpoint
Best regards and thank you
