Intel vPro® Platform
3051 Discussions
How to push file to broken down AMT machine
Example:
AMT machine miss a boot file. we want to push this file to AMT machine.
We use IDE-Redirect Floppy / CD/DVD boot AMT machine, but we can't found the driver of AMT machine.
The ISV is HP openview, how can we push the file?
Brian_Cockrell
Alex provides some ideas here http://communities.intel.com/openport/message/2445 to copy files to your client system.
You will need to have a boot image (either floppy based or CD/DVD based) that will have access to the missing file, probably on a network file share, and be able to update the disk of the failed machine. There are several diagnostic boot images and processes to build your own available on the web. You can start at http://www.ultimatebootcd.com/ for discussions and examples of how to build your own.
HP does not supply any diagnostic boot images.
The Intel link provided in Alex's reply on this thread is a good source of information, too.
regards,
Rick WInford
HP Software
