Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3090 Discussions
How to remotely access a VPro enabled workstation connecting thru a VPN?
We want to manage a lot of workstations via the KVM remote control (or any other remote control Using Intel vPro Solution Manager). How can I accomplish this? Do I need to assign the static (or via the VPN DHCP server) IP of the Cisco VPN adapter. Do we need to enable the KVM redirection feature of "KVM-Remote" Control so it will listen to the VPN adapter? The remote session is over the internet so we want to make sure there is a security mechanism involved. I called Dell and gave me this forum.
Tik
MichaelA_Intel
Hi Tik
I'd like to request that you go ahead and open a ticket for assistance on this so that we may assist you further. For convenience, I'd open the ticket myself on your behalf, however, I do not have enough detail to do that. You can open a ticket here:
http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Choose
  • Intel® vPro™ Technology
Let us know how many workstations you plan to manage.
In the meantime, I'd also like to point you to some reference material so that you can be introduced to Intel® vPro™ Technology and the software that you will need to accomplish this.
This link takes you to the AMT implementation and reference guide:
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm
You can also download the Intel® Setup and Configuration Software (Intel® SCS) here:
https://downloadcenter.intel.com/download/26505/Intel-Setup-and-Configuration-Software-Intel-SCS- https://downloadcenter.intel.com/download/26505/Intel-Setup-and-Configuration-Software-Intel-SCS-
and download the SCSdownload_package_11.1.0.75.zip
The root of the zip file contains the user guide which should help to answer your questions in further detail.
