- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Phil,
Greetings!
Could you please confirm the console (EMA, mesh central) you use to manage the endpoints?
We also request you to share the Intel® EMA Configuration Tool (ECT) logs from both machines.
Steps to Generate ECT Logs:
Download the Intel® EMA Configuration Tool (ECT):
Download ECT: https://www.intel.com/content/www/us/en/download/19805/30485/intel-endpoint-management-assistant-configuration-tool-intel-ema-configuration-tool.html
1.Installation:
- Download and unzip the tool.
- Double-click the .msi file and follow the prompts to install it.
2.Run the Tool:
- Open a Command Prompt as Administrator (or Windows PowerShell*).
- Navigate to the installation folder (default path: C:\Program Files (x86)\Intel\EMAConfigTool).
- Run the following command:
EMAConfigTool.exe --verbose
Vijay N
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello pzhang13,
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
We appreciate your understanding!
Vijay N
Intel Customer Support.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello pzhang13,
Please note that Intel® vPro™ is only supported on Intel processors, motherboards, and embedded network cards (both wired and wireless).
If further assistance is necessary, do not hesitate to reply.
Vijay N
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
