Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3090 Discussions
Intel AMT IDE-R Not working
Hassan-Engineer
Hello
I am currently managing vPro machines with ME version v11.8.83
The IDER Boot does work fine on AMT vPro 11 Machine.
SOL/IDER settings in the MEBx enabled already
How to use this ide-r & how much size it's supported, if i have to install the OS to remote machine ???
Please help!
Thank you!
JoseH_Intel
Hello Hassan-Engineer,
Thank you for joining the Intel community
Do you know what if the system you are trying to USB-R is in Client Control Mode or Admin Control Mode? It depends a bit on the provisioning method used. If the system is in Client Control Mode it will require User Consent from the target machine to allow USB-R.
Can you tell what remote tool are you using Intel Manageability Commander, Mesh Commander, or any other? Since AMT v11 and higher IDE-R was replaced with USB-R. Chances are you are seeing a deprecated (grayed out) option and you want to look for USB-R
Let me know if this helps
Jose A.
JoseH_Intel
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. I will try to reach you on next Tuesday 22nd. After that the thread will be archived automatically.
Jose A.
JoseH_Intel
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
Hassan-Engineer
Yes am seeing a deprecated (grayed out) option and want to look for USB-R, i am using MechCommander for manageability
