Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Intel AMT - Issue with static IP address
vpa
I'm using static IP address of the iAMT many years. I'm trying to change this to something more compatible with Mesh central and MeshAgent. I have different versions of iAMT, up to 15.x.
When I change IP address of iAMT on computer, which has 15.x version, to the same ip address as the address of PC, when the computer is power off, iAMT (ping, 16992 page,...) doesn't respond, when is on, iAMT is responding. When IP addresses are different, iAMT responds regardless of state of PC and is possible to power on PC when is off and so on. Where I'm wrong. Thanks
JoseH_Intel
Hello vpa,
Thank you for joining the Intel community
When you say you have different versions and the one trying to change the static IP address is running on 1.5.x do you refer to Intel EMA? You could try to update to the latest version 1.7 Intel® Endpoint Management Assistant (Intel® EMA)
Or, are you referring to the Intel EMA SDK version 15? The latest one is v16.0.3.1 Intel® AMT SDK
About the issue you describe, it seems like a compatibility problem between AMT and MeshCentral. Remember that MeshCentral is an Intel not-official opensource software. For suggestions or support you will need to contact MeshCentral support Open Software Projects - Contact Information (meshcommander.com)
Jose A.
vpa
Working version of iAMT is v9.x. I think it is incompatible with Intel EMA 1.7, so I couldn't use EMA.
JoseH_Intel
Hello vpa,
You are correct, EMA works with AMT v11 and higher.
About the MeshCentral issue, for support you will need to contact MeshCentral support Open Software Projects - Contact Information (meshcommander.com)
Jose A.
vpa
In summary.
It has nothing to do with MeshCentral. MeshCentral is not installed on iAMT interfaces, it is different product.
Intel EMA is not possible to use, because older version of iAMT are unsupported.
Version 15.x of iAMT has different behavior than previous version (for example 9.x). It is not working when computer is power off, when has same ip address as computer.
