Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Intel AMT KVM Remote Desktop not Available
R88
 We have HP Prodesk 600 G5 with Intel i5-9500T processor that supports vPro. When connecting using MeshCommander and Intel management Commander, KVM Remote Desktop is not an option. Is there a setting that we are missing to get this enabled?
JoseH_Intel
Hello R88,
Thank you for joining the Intel community
Is your HP Prodesk 600 G5 system already provisioned for AMT remote management? Could you tell which method did you use to provision it (USB key, remote configuration, MEBx setup)?
The KVM capability needs to be enabled before the Intel AMT platform will allow a KVM session to start. Once KVM is enabled, connections can be made using the redirection ports – 16994 (non-TLS) or 16995 (using TLS).
For more details, you can do a search by KVM under the following URL: https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm
Hope it helps
Jose A.
Intel Customer Support
JoseH_Intel
Hello R88,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this ticket as closed. This support interaction will be marked as resolved automatically in the next 72 hours if no activity is received. I will follow up with you again next Monday 13th. If you prefer a different date just let me know.
Jose A.
JoseH_Intel
Hello R88,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and submit a new post.
Regards.
Jose A.
A Contingent Worker at Intel
dchang92606
I have the same problem.  I read through the Intel doc, but I have different menus in my ProDesk 600 G5 Mini.  In my menus, there's no mention of KVM (just SOL).  I have a 9500T vPro CPU.  Does the HP ProDesk 600 G5 Mini PC support remote KVM using AMT or not?
