Intel vPro® Platform
3052 Discussions
Intel SCS 9.1 is missing the button "KVM settings"
TJori
I use the ACUwizard to create an AMT profile to deploy to all computers supporting vPro.
I use the latest version of Intel SCS (9.1.2).
On the section "System Settings" you've got the option to choose which management interfaces you want to enable.
One of them is "KVM redirection". Default this is configured with "user consent required before beginning KVM session".
According to the manual of SCS 9.1 there should be a button "KVM settings" next to the option "KVM redirection", but there isn't one...
Anyone got a solution to disable user consent for a kvm session ?
Kind regards,
Tom
Bruno_Domignues
Tom,
in order to disable KVM consent, you must provision machines in Admin Control Mode, i.e. PKI, using certificates or PSK. Are you using one of these methods? You can't disable consent using Host Based Configuration.
Best Regards!
-Bruno Domingues
