Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
Intel Socket 775
What is the best mother board to replace this one P5P800 SE? They don't make this anylonger and I really have to find an upgrade that's an ATX form factor. All my client needs it for is the surveillance system. I hope to upgrade to a full Intel board instead of an Asus with Intel on it. Here are the specs, I hope someone can help because I need it and I would appreciate anyone with this knowledge.
P5P800 SE
CPU
Intel Socket 775 Pentium® D/Pentium® 4/Celeron Processors
Compatible with Intel® 05B/ 05A and 04B/04A processors
Support Intel® EM64T/ EIST/ Hyper-Threading Technology
Chipset
Intel 865PE
Intel ICH5
Front Side Bus
800/533/ MHz
Memory
4 x184-pin DIMM, Max. 4 GB, DDR 400/333/266 SDRAM ,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
ASUS Hyper-Path Technology
Expansion Slots
4 x PCI
1 x AGP 8x / 4X (0.8V, 1.5V only)
Storage
Southbridge
2 xUltraDMA 100/66/33
2 xSATA 3 Gb/s ports
USB
8 USB 2.0 ports
Audio
ADI AD1888 SoundMAX 6 -Channel audio CODEC
S/PDIF out on back I/O port
LAN
Intel 82540EM Gigabit/ LAN Controller supporting BASE-T Ethernet 100/10
Overclocking Features
Intelligent overclocking tools
- ASUS CPU Lock Free
- AI Overclocking (intelligent CPU frequency tuner)
- CPU and Memory voltage adjustable
SFS (Stepless Frequency Selection)
- FSB tuning from 100MHz up to 400MHz at 1MHz increment
- Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
ASUS MyLogo
ASUS EZ Flash
ASUS CrashFree BIOS 2
ASUS Q-Fan
Back Panel I/O Ports
1 x Parallel
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Serial port
1 x S/PDIF Out
1 x LAN(RJ45) port
4 x USB 2.0/1.1
6 -Channel Audio I/O
Internal I/O Connectors
2 x USB connectors supports additional 4 USB 2.0 ports
1 x Floppy disk drive connector
2 x IDE connector
2 x SATA connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x S/PDIF Out connector
1 x4-pin ATX 12V Power connector
24 -pin ATX Power connector
Front panel audio connector
Game/MIDI port connector
Chassis Intrusion connector
CD/AUX audio in
System Panel Connector
BIOS
4 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
Manageability
WOL/WOR by PME,Chasis Intrusion,PXE,RPL,
Support Disc
Drivers
ASUS PC Probe
Anti-virus software (OEM version)
ASUS LiveUpdate Utility
Accessories
User's manual
x IDE cables
x UltraDMA 133/100/66 cables
x Floppy disk drive cables
x SATA cables
SATA power cables
I/O Shield
Form Factor
ATX Form Factor
12 inch x 8.4 inch ( 30.5 cm x 21.3 cm )
Hey there QT.
We also used to use many of the ASUS motherboards, but can now get Intel units for the "right price", so no longer use the ASUS units. I asume you are wanting a smilar motherboard so as not to have to relaod the operating system & security applications ? (Let me guess, the client no longer has any installation media, and the security company is long gone?)
We have most recently been using the DQ38J series to replace failed LGA775 series ASUS motherboards. The chipsets (apart from VIA based units) appear to be similar enough that the PC will at least boot and an operating system repair can be performed from there.
Good Luck,
Davo.
