Intel vPro® Platform
3077 Discussions
Intel vPro KVM session displays RealVNC flash popup
Is there any way to remove the flash screen which pops up when I use SCCM Intel vPro KVM? I need to take screen dumps and this won't go and I cannot see all the information necessary.
Joseph_O_Intel
Where did you get the plugin module for SCCM?
Joseph_O_Intel
Your version of RealVnc is an evaluation version only, once you get a full licensed version the pop up will no longer be an issue.
Where did you get the RealVNC software? Was it bundled with the SCCM plugin module?
We use RealVNC free edition just to get onto historical systems. I don't believe it was bundled, but I am unsure. I had previously installed and then uninstalled RealVNC + as this gave secure authentication and I was testing it in conjunction with another project.
Joseph_O_Intel
Thanks for the feedback.
At this point I would just reinstall your RealVNC+ and that should solve your issue.
