Intel vPro® Platform
3057 Discussions
Is there a way to change the Mebx password remotely once a system has been provisioned?
ASald4
I am currently implementing vPro in my organization and could use some assistance. I used a USB Drive to set the Mebx password initially. I used the default password of admin, and then the usb key changed the password to my 32 bit string. That worked well. I now have setup profiles in the SCS console to my liking, and everything is working correctly. However, I still have not found a way to change the mebx password since then. I can change the password if I create a new USB key, or if I manually enter the new password into the mebx, but how is this accomplished using either ACUConfig or with a profile? Is this even possible? I have done a ton of searching and have not yet found an answer to my question.
Alex
