Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3085 Discussions
Network Drops.
HP desktop Dc7800 with VMware workstation installed.
When we are running images in vmware with AMT bios enabled, we receive sporatic network drops in the VM image.
I doubt that this would be directly related to the vPro chipset, although I won't rule it out either. Let's start with some basics ... do you have the VMware Tools installed on the VMware guest operating system? What are your host & guest operating systems?
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
VMware tools installed = yes
VMware guest OS = Windows 2000
Host OS = Windows Vista
Terry_C_Intel
Is Intel AMT configured on the unit? (SMB or Enterprise mode)
Is there an interval to the disconnects being observed?
On the HP system - any security features on the local host OS (open which VMware is running) to note? (Windows Firewall, HP security manager, other)
Please submit following data:
  • HP BIOS rev
  • Intel AMT firmware rev
  • configuration state of Intel AMT firmwar
There's a handy utility - AMTSCAN - that will quickly capture this and related information. Information on the utility is available at http://communities.intel.com/docs/DOC-2062 http://communities.intel.com/docs/DOC-2062
Is Intel AMT configured on the unit? = SMB
Is there an interval to the disconnects being observed? = Random
On the HP system - any security features on the local host OS (open which VMware is running) to note? = Symantec Client Security
  • HP BIOS rev
>>There's a handy utility - AMTSCAN - that will quickly capture this and related information. Information on the utility is available at >>http://communities.intel.com/docs/DOC-2062 http://communities.intel.com/docs/DOC-2062 -
Could not get utiltiy to work. Please assist.
Went into the bios, here is some info
System Bios = 786F1 v0.126
ME firmware version = 3.0.1.1104
Went into the AMT Bios
Intel Management Engine Bios Extension version is showing 3.0.2.0004
Question - why is there a difference in the ME firmware versions?
Terry_C_Intel
The latest Intel AMT firmware version for that platform is at 3.2.2 - at the link shown by Brian above.
When you do the HP BIOS update - there's a separate process for updating the Intel AMT firmware. This is how HP chose to implement the firmware update packages.
I have similar problem to a windows xp guest and following is how I resolved the problem:
Issue before:
Guest network adaptor using NAT
Network drops from time to time
Fix:
Guest network adaptor using Bridge (but VPN not work until I do following step)
Host go to Network Connections and open the properties for "VMware Network Adapter VMnet1"
Make sure the "VMware Bridge Protocol" is checked
After the fix, the network have not drop so far. Hope this help.
