Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
SCCM Task sequence and vPro
With SCCM sp1 you can obviously manually initiate a vPro Power Off to a pc in a specific collection but is it possible to incorporate the vPro Power Off command in an SCCM Task Sequence?
If so how?
What vPro management functions cannot be Task Sequenced?
Matthew_R_Intel
There is nothing native within SCCM SP1 that allows you to schedule an AMT Power Off command; however, typically you would want to use the agent to gracefully shutdown the OS so not to inadvertently corrupt the OS (you can use a task sequence command such as shutdown -s -f to perform this within the OS gracefully). You can; however, set up an advertisement to wake up the vPro client using an AMT power control command. Please reference the p-11318 following blog.
If want you to perform a AMT power off command from a task sequence, you can use a run command task within SCCM and leverage the http://communities.intel.com/docs/DOC-1767 Remote Control Utility
--Matt Royer
