Intel vPro® Platform
3072 Discussions
SCCM activation error: Failed to Call CheckCertificate provider method, 80041001
I'm trying to activate some vpro's machines and I'm getting the error (in oobmgmt.log):
BEGIN oobmgmt 3/16/2011 8:38:33 AM 3976 (0x0F88)
Retrying to activate the device. oobmgmt 3/16/2011 8:38:34 AM 3976 (0x0F88)
Raising event:
[SMS_CodePage(850), SMS_LocaleID(1046)]
instance of SMS_OOBMgmt_StartConfig_Failure
ClientID = "GUID:DAA40499-E821-4EAD-9EFF-EF12890FF65F";
DateTime = "20110316113834.022000+000";
ErrorCode = "1";
FailureCategory = "None certificate is valid between device and server certificate hash.";
MachineName = "MICP104533";
ProcessID = 1620;
SiteCode = "C02";
ThreadID = 3976;
Successfully submitted event to the Status Agent. oobmgmt 3/16/2011 8:38:34 AM 3976 (0x0F88)
Failed to Call CheckCertificate provider method, 80041001 oobmgmt 3/16/2011 8:38:34 AM 3976 (0x0F88)
END oobmgmt 3/16/2011 8:38:34 AM 3976 (0x0F88)
My machine is a DELL Optiplex 780. Running the MEInfo I get this info:
AMT SKU Found.
Intel(R) MEInfo Win Version: 3.0.0.1077
BIOS Version: A01
Intel(R) AMT code versions:
Flash: 5.2.0
Netstack: 5.2.0
AMTApps: 5.2.0
AMT: 5.2.0
SKU: IAMT
VendorID: 8086
Build Number: 009
Recovery Version: 5.2.0
Recovery Build Num: 1009
Legacy Mode: False
Link status: Link up
Cryptography fuse: Enabled
Flash protection: Enabled
Last reset reason: Global system reset
Setup and Configuration: In process
BIOS Mode: Post Boot
Error: The operation failed due to an internal error.
FWU Override Counter: Always
FWU Override Qualifier: Always
FW on Flash Desc Override: Disable
UNS Version: 5.0.5.1034
LMS Version: 5.2.0.1034
HECI Version: 5.2.0.1008
Looking into the WMI class, through Powershell I get this:
PS D:\> $PrvSrv = [wmiclass]"root\ccm:CCM_PrvsMethodProvider"
PS D:\> $PrvSrv.CheckCertificate("74 2C 31 92 E6 07 E4 24 EB 45 49 54 2B E1 BB C5 3E 61 74 E2".Replace(" ",""))
__GENUS : 2
__CLASS : __PARAMETERS
__SUPERCLASS :
__DYNASTY : __PARAMETERS
__RELPATH :
__PROPERTY_COUNT : 4
__DERIVATION : {}
__SERVER :
__NAMESPACE :
__PATH :
dvcCert : 742C3192E607E424EB4549542BE1BBC53E6174E2
ErrorCode : 0
ErrorMsg :
ReturnValue : 0
So, I think I'm able to activate this device, but I still get the error in the SCCM Client activation.
Someone can help me to find out what's happening?
Thanks in advanced.
Perazza
Hi Perazza,
What provisioning certificate are you using? Check the thumbprint of the Root Certificate of the CA that issued your provisioning cert. If it is not one of the hashes that is currently shipping with our firmware, you will need to enter it manually.
Josh
My provisioning certificate was correct. I just needed to wait until the activation process took place. I don't know what happened. But it's working fine now.
Tks for your reply
