Intel vPro® Platform
3058 Discussions
Sccm 2012 r2 oobm - exit with code 68. Details: invalid parameter was found. (RCSAAddress)
JLouw
We are using Sccm 2012 R2 and want to implement Oobm. So we followed this guide in our test environment: http://sccmguru.wordpress.com/2013/12/20/integrating-configuration-manager-2012-r2-with-intel-scs-9-0-part-1/ Integrating Configuration Manager 2012 R2 with Intel SCS 9.0 – Part 1 : Introduction | SCCM GURU
Provisioning is working fine on Fujitsu computers with AMT version 7 and 9. But on older hardware with version 5 and 6 there is an error during configuration of the profile.
exit with code 68. Details: invalid parameter was found. (RCSAAddress) is found in the Windows event viewer.
and in the Sccm console AMT Status is Not Supported (version 6) and Detected (version 5).
Version 7 and 9 are having the status Provisioned and the out of the band management console is working.
AAlde4
As a reminder, direct support from Intel engineers is available at https://bizsupport.intel.com/ https://bizsupport.intel.com.
Bruno_Domignues
Based on what you explained, my guess is that you are provisioning these machines using HBC (i.e. Host Based Configuration) method that is not supported in ME versions <6.2. Can you confirm?
Best Regards!
Bruno Domingues
JLouw
I am bit new to this. But I think you are right. So for ME versions <6.2 I need to set up a SCS with a dns record "ProvisionServer".
This SCS can be installed on my Sccm server. But wil it be intergrated in Sccm?
Bruno_Domignues
"ProvisionServer" DNS record is not required for provision in this scenario, it's a legacy resource used by old AMT versions to find the SCS, even when you don't an Operating System.
For AMT <6.2 you must use PKI provisioning that rely on 3rd party certificates for provision, since these versions does not support HBC - In Intel Setup and Configuration Software (Intel SCS) User Guide that you can find in Intel <a href="https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20921">SCS package, chapter 10.
In order to integrate with Microsoft SCCM, you can use the https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20921 Intel SCS Add-On for SCCM installed in SCCM Server.
There is no requirement to put Intel SCS and SCCM in the same box, usually the best practice is install Intel SCS in a dedicated server/VM.
Best Regards!
-Bruno Domingues
