Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
Sensors
What about the sensors in upcoming mobile products ? detials about their working and type
JLodh
New Contributor II
Can you be a little more specific and elaborate what sensors are you seeking information on cause there are many types of sensors available for mobile products.
Warm Regards,
Javed Lodhi
Intel Go Green! Save the Environment
Now I am planning take over a project. I have to stimulate a sensor network and implement algorithm for hole detection etc., so i want know how do compainies actually simulate and test.(help regarding choosing of simulators of sensor networks )
JLodh
New Contributor II
First of all, simulation of sensor networks is a question that does not belong to vPro Expert Center, second as I already mentioned that if you could kindly state specifically what type of sensors are you seeking information on.
If you are looking for sensors for network simulation, I'd recommend that you explore a few of the following URLs and just in case you need more assistance regarding that, post in IT@Intel so that we are better able to address your need.
http://www.cs.rpi.edu/~cheng3/sense/
http://ieeexplore.ieee.org/iel5/4297370/4297371/04297441.pdf?arnumber=4297441
http://www.cs.ucla.edu/~palsberg/sns/
http://www.cs.virginia.edu/~sb2jb/project/files/simulator_pres.ppt
http://repositories.cdlib.org/cens/Posters/93/
http://portal.acm.org/citation.cfm?id=1163653.1163661
http://www.hynet.umd.edu/research/atemu/
Warm Regards,
Javed Lodhi
Intel Go Green, Save the Environment!
