Intel vPro® Platform
3051 Discussions
Upgrading from EMA v1.12.2.0 to Intel® EMA v1.13.1.0
Hideo
Hi.
What is the procedure for vergen up from Intel® EMA v1.12.2.0 to Intel® EMA v1.13.1.0?
The Intel® Endpoint Management Assistant (Intel® EMA) Cloud Start Tool for Azure* (Advanced Template) was used to install Intel® EMA.
The download URL is as follow
The version of Intel® EMA in the template was v1.12.2.0.
Therefore, we attempted to upgrade the version.
The method implemented is as follows.
・Uninstalled Intel® EMA v1.12.2.0.
・Then reinstalled Intel® EMA v1.13.1.0.
 *AzureSQL was used for SQL at that time.
Intel® EMA could be installed, but I could not remote control the agent terminal from Intel® EMA.
Therefore,
What is the procedure for a regular upgrade from Intel® EMA v1.12.2.0 to Intel® EMA v1.13.1.0.
We are waiting for your reply.
Best regards.
Hideo.
Arun_Intel1
Hello Hideo,
Greetings!
As shown, you may follow the template to create a new user in the EMA, and if you are looking for creating the new production environment then please use the Azure to create a new virtual machine and database and proceed.
Kindly note that this template is for the test environment, and has limited option for testing purposes.
Best Regards
Arun_Intel
