Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3089 Discussions
User Consent Policy Problem
MKies1
i integrated Intel SCS with SCCM 2012.
All things are working fine, but if i configured my AMT machine with an RCS profile and the setting "No User Consent required" the Intel KVM console requires everytime a user consent.
At the AMT Machine in the Control Utility it stands "No User Consent required for any session" and the Machine is in Admin Mode, so it seems ok.
If i use VNC Viewer Plus then i can go in with no user consent, depending on what configured in the settings before i establish the connection.
The Intel KVM Console for SCCM i used is this here:
https://downloadcenter.intel.com/download/21835 https://downloadcenter.intel.com/download/21835
I think there is missing user consent feature in this console or is there a hidden setting?
Thanks four your suggestions.
Michael
MKies1
I have to correct myself: If i set "No User Consent required" i get immediately disconnected with the Intel KVM Tool:
At the AMT machine:
Dariusz_W_Intel
Michael,
Admin Control Mode (ACM) allows User Consent Code setting to be set to one of three possible states:
  • None (this is your setup)
  • KVM Only (default state after configuration unless you uncheck "Consent required" checkbox in AMT profile with SCS console)
  • All Redirection Applications (equivalent of CCM settings).
This setting is per Intel® AMT based system NOT per AMT user account or session.
This is Intel® AMT setup part.
Then there is KVM Viewer part – some of KVM Viewer applications (like Real VNC Viewer Plus or Intel KVM View) allow to be set to override User Consent setting, but it requires:
  1. Intel® AMT to be configured in ACM (to make User Consent Code setting be changeable at all)
    - AND -
  2. Current KVM Viewer App user to have PT Administration ACL Realm (be Intel® AMT administrator) – either using default Intel® AMT Digest administrator (admin) or any Intel® AMT AD/Digest account with PT Administration realm assigned (in AMT Profile)
I think in your case you have Intel KVM Viewer app (part of MS SCCM vPro Add-on) configured to use User Consent Code so it tries to change User Consent Code setting from None to KVM Only – and as account running it may not have PT Administration Realm Intel® AMT refuses this request.
To change it :
  1. open Intel KVM Viewer app alone (64 bit version - C:\Program Files\Intel Corporation\Intel Core vPro processor add-on System Center Configuration Manager\KVMView.exe,
    32 bit version - C:\Program Files (x86)\Intel Corporation\Intel Core vPro processor add-on System Center Configuration Manager\KVMView.exe)
  2. Click Options button and in Session Settings
  3. uncheck Require User Consent.
  4. Click Apply.
    rgds
    darek
MKies1
Hi Dariusz,
thanks for this Information. I will search and try the Option you mentioned here.
I searched for this Option in Intel KVM Addon (after i saw it in VNC Viewer) but i don't see it maybe ;-)
Michael
