Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Using vPro across vlans
Does anybody have this working? I can easily provision a device when on the same vlan as provisioning server. If I try from a vlan it is connected enough to know if I typo the PID or PPS, but that's it. I can browse the webui to a provisioned machine only from same vlan. No firewalls in play. Simple Cisco 6509 core with no extra blocks in place. I'm using LANDesk core as my provision server. Enterprise mode, DHCP. AMT versions 3 and 5 tested with same results. I can telnet across vlans (to verify port listening) to simple ports like 8081, but not 16993. I CAN telnet and verify port 16993 listening from another machine on same vlan.
I have my issue resolved.
In our situation we can't configure default gateways (per PCI auditors) so our default vlan gateways are configured using option 249 Classless Static Routes in our DHCP server. Normal DHCP default gateway setting is configured using 003 Router. Once I configured a default gateway on a vlan DHCP Scope using 003 Router I was able to provision across vlans, browse across, and administer using LANDesk console.
The reason I assumed we had full two-way network connectivity was the fact that if I incorrectly entered a PID or PPS while provisioning on a vlan client it displayed "incorrect entry" so somehow it was able to verify this against the provision server (different vlan) since I was using PID and PPS info I generated.
Hi 5DANdesk I just finished working with a company with a similar issue - they ran vLan and successfully deployed/provisioned and managed the clients , then they created "Y" vLan and lost there ability to manage or discover - we need to review the basics so bear with me for a minuteW5
1. you have a switch between the vLans, did you confirm all necessary ports are open - 16992 etc... including the provisioning port? sounds like you did
2. did you set the new boundaries of the IP range on your DHCP server?
now the tircky stuff
vPro does pull default gateway information from the DHCP server. In our situation we can't configure default gateways (per PCI auditors) so my customers environment the default vlan gateways are configured using option 249 Classless Static Routes in there DHCP server. Normal DHCP default gateway setting is configured using 003 Router. Once I configured a default gateway on a vlan using 003 Router I was able to provision across vlans, browse across, and administer using ISV console. vPro appears to have an issue handling the 249 Route option so the customer will need to develop a plan possibly using manual IP configuration.
