Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
VPro and Pointsec
Is it possible to login on a machine with Pointsec disc encryptation with Vpro???
Are you referring to the ability to bypass a pre-boot authentication screen? If so, I'm not aware of any method of remotely logging into such a portal using vPro 5.x or less, since Serial-over-LAN only supports text-based "GUIs".
Cheers,
Trevor Sullivan
When the mahine starts up Pointsec is placed in the MBR and is involved in the boot up but as soon as it has started a GUI comes up which you can fill in your loginname and Pointsec password. This is what I have need of to doing remotly. Is that possible?
