Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
WS-MAN Translator Configuration Wizard Error
SWood7
Running into an odd error running the WS-Translator Configuration Wizard. On the Select TLS/forwarding options dialog, I've selected my cert, clicked Findished and got this message:
"An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)"
I can click OK and it will prompt me to restart the translator service. Can I assume everything is ok or is there a test to see if the service is correctly configured?
Matthew_R_Intel
That was indeed odd. If you go to https://<fqdn_of_sccm_server>/wstrans https://<FQDN_OF_SCCM_SERVER>/wstrans does the Intel WS-MAN Translator page load? That certificate is used to secure communicate to the WS-MAN Translator Web Service.
--Matt Royer
