Intel vPro® Platform
3057 Discussions
activator.exe syntax for connection to SCS and automatic setup
Hi, im trying to figure out how to use the activator.exe to contact the scs (provisionserver.domain.intern), transfer the fqdn, select a profile from inside the SCS and install it. Im up to install a way to rollout this all without using landesk, altiris and so on.
Im using PSK in enterprise mode. In the future the PCs shall reach us preconfigured with PID/PSK keypair, atm i testing it by installing the PSK by USB.
I installed SCS 6.0.25 (with patch) on the provisionserver, created PSK on a usb-stick, booted the computer and installed the key. no problem this far.
I went to /docs/DOC-1171 http://communities.intel.com/docs/DOC-1171 (last update december 2010), followed the linkt to the activator (/docs/DOC-1787 http://communities.intel.com/docs/DOC-1787). Then i found the link to http://software.intel.com/en-us/articles/intel-vpro-technology-activator-utility/ http://software.intel.com/en-us/articles/intel-vpro-technology-activator-utility/
the next-generation of the remote-control-utility. (By the way - why does the download-link go to old 2008-stuff oO)
Using this intel_vpro_technology_activator_utility_3.3 i was able to contact the scs .
with the string
activator.exe /s http://provisionserver.domain.intern/amtsc http://provisionserver.domain.intern/amtsc /t on /c /f
i activated the amt, got the fqdn transfered and sent hellos. It created an error, exit with 7, but i found it on the scs and could do the rest ( choose profile, configure) from there
after that i found the activator.exe delivered with the SCS 6.0.24 ( >.<) . Far more complicated and with a different syntax ( e.g. /destination <scs_address> instead of /s ).
By now im completely confused what to use and how to write the order.
What i want to do: roll out the activator.exe on a target system by a software-distibution-system like enteo, start it with a batch there.
in this batch there should be a string " activator.exe .........."
with all drivers installed in the os the activator.exe SHALL contact the provisionserver with PSK, transfer the fqdn of the system, choose a specific profile out of 3, install it on the AMT-PC. Probably i have to use username/password in this line to be allowed to connect to scs ?
the activatorwizard_exe does the trick - it uses the activator.exe as well.
What do i have to write behind activator.exe ?
Please help me.
No one with an idea ? Syntax or a bestpractice?
Hi Garath,
The command you need to use with Activator 6.x(not 3.3, you can find it in the Activator wizard "Bin" folder. It uses it also) is:
"Activator.exe /destination /profileid [/username /password ]"
- the SCS server FQDN (No Http…), in your case can be : "provisionserver.domain.intern"
- the profile you created ID(number)
- only if needed, the user that have WMI privileges on the SCS server machine. (see the documentation for how to add that privilege if needed)
- the user password.
For more options you can run "Activator.exe /?"
Now a little bit more detail:
Activator version 3.x-5.x connects to SCS 3.x-5.x that uses IIS interface to connect and control the SCS server.
SCS 6 uses Microsoft WMI namespace to connect and control the Server, so Activator 3 won't be able to connect SCS 6.
If you have more questions please post them here,
