Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
iSCSI SAN device
iSCSI SAN device "Intel Storage System SSR316MJ2". How to install and configure on windows OS?
JLodh
New Contributor II
Anees,
I believe you are trying to install Windows on SSR316MJ2.
First, Intel ended its interactive support (EOIS) over MJ2 with effect from
Jan 10, 2008 meaning that Intel no longer provides support over MJ2 via email
or telephone however the technical support web contents are still available on
Intel's support website.
Second, it's okay that this question has been posted in vPro Center however
just to bring this to your knowledge, since storage devices especially
SSR316MJ2 falls in Server class, this question belongs to The Server Room.
Now coming to your question, you have asked a very generic question not
specifying the exact problem you are encountering. You need to specify your
exact scenario and the OS you are trying to install so that it gives us a clear
picture so that we are able to guide you.
Moreover, if you want to access the web support and driver/document
repository for SSR316MJ2, here is http://www.intel.com/support/motherboards/server/ssr316mj2/ SSR316MJ2 SUPPORT PORTAL which I am sure will resolve a lot of your problems and assist you
in deployment. But I would again emphasize that you please give us a clear
picture of your scenario since the iSCSI SANs come with a DOM (Disk On Module)
which contains a pre-installed OS, RAID drivers and utility and what I presume
here is that you are probably trying to install Microsoft Unified Storage
Server 2003 on a SSR316J2.
Fill us in with your exact scenario and requirement so that we are better
able to provide you support.
Warm Regards,
Javed Lodhi
