- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi guys, we experience a strange issue with proxy-autoconfig/wpad (proxy.pac).
The JavaScript-function myIpAddress() which should return the clients IP-address always returns 127.0.0.1.
This function is used to determine when the client should use the corporate proxy or go directly to the internet based on which subnet its on.
We tracked down the problem to be caused by the following lines which the AMT LMS-agent appends to the client computers hosts-file during installation:
# 127.0.0.1 localhost
127.0.0.1 computername # LMS GENERATED LINE
Please notice that the original line is commented out by the AMT agent.
If we remove the line AMT added, the proxy.pac-script works just fine.
What is the purpose of LMS changing the clients hosts-file like this? Does it have something to do with SOL or console-redirection?
Is there a way to work around this issue?
PS. I see the same behavior both with the AMT/MEI-drivers from Intel directly as well as those from Lenovo. The drivers from HP also have this behavior.
Cheers
Rolf
Link kopiert
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
