Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
unprovision
citynews
hi after updated to 1.7.1 some device went in client mode.so i need to unprovision this client remotly with an utility.i see there is an intel amt unprovision utility i cant downlod beacouse the link is not valid .can you help me please?
JoseH_Intel
Hello citynews,
Thank you for joining the Intel community
The fact that the clients are provisioned in Client Control Mode (CCM) is related to the original provisioning method used. If no PKI certificate was used then the clients provision in CCM. So this should not be related to the recent upgrade to v1.7.1
About unprovisioning methods there are the MEBx unprovisioning (requires physical access to the machine) and the old ACUconfigurator from the Intel® Setup and Configuration Software (Intel® SCS). It is contained in the download package and it is a CLI tool. For the syntax check here https://www.intel.com/content/dam/www/public/us/en/documents/guides/amt-configuration-utility-user-guide.pdf#page=99
Unfortunately the AMT Unprovision tool is no longer available
You can merge this thread into AMT Profile Unprovisioning - Intel Communities which is related to the exact same topic.
Jose A.
