Intel vPro® Platform
3053 Discussions
what port should be open when install add-on on a seperate SMS console
we want to help the EU deploy vPro .The EU's manage console is SMS, the EU use a seperate SMS console which run on different machine with SMS server, there is a firwall between the SMS console and SMS server, my questoin is: if we install the add-on on the console, what port should we open on the firwall except the ports SMS needed?
thanks,
-Jen
Matthew_R_Intel
On page 51 of the Intel® Active Management Technology Add-on for Microsoft* SMS 2003 Installation and User's Guide, it lists the ports that need to be opened. (http://softwarecommunity.intel.com/isn/downloads/Manageability/Intel_AMT_Add-on_for_SMS_UserGuide.pdf )
--Matt Royer
thanks very much. i consider except these ports, the console need some other ports to commuicate with SMS server. Now, i unserstand, only these ports needed.
-Jen
You need open below ports:
amt-soap-http 16992/tcp Intel(R) AMT SOAP/HTTP
amt-soap-http 16992/udp Intel(R) AMT SOAP/HTTP
amt-soap-https 16993/tcp Intel(R) AMT SOAP/HTTPS
amt-soap-https 16993/udp Intel(R) AMT SOAP/HTTPS
amt-redir-tcp 16994/tcp Intel(R) AMT Redirection/TCP
amt-redir-tcp 16994/udp Intel(R) AMT Redirection/TCP
amt-redir-tls 16995/tcp Intel(R) AMT Redirection/TLS
amt-redir-tls 16995/udp Intel(R) AMT Redirection/TLS
amt-conf-http 9971/tcp/udp Intel AMT configuration service port.
Bill
