I have this bug when when I am trying to run RealSense camera with Matlab (I am using D435 version):
Undefined variable "realsense" or class "realsense.librealsense_mex".
Error in realsense.config (line 9)
this.objectHandle = realsense.librealsense_mex('rs2::config', 'new');
Error in realsense.rosbag_example (line 3)
cfg = realsense.config();
This happens when I try to run the code that I found here:
https://github.com/IntelRealSense/librealsense/tree/master/wrappers/matlab.
for example when I try to run "rosbag_example.m".
The camera works when I use it without Matlab, but when I use it with Matlab I get this bug. Also a month ago the same code worked, and I succeeded using the camera with Matlab, but now it is not working.
Please visit the discussion linked to below and read downward through the comments from the point in the discussion that I have linked to. I hope there will be something in that advice that helps with your problem.
https://github.com/IntelRealSense/librealsense/issues/3241#issuecomment-462921243
