Items with no label
3341 Discussions
Acquire non-depth limited RGB image stream while handtracking
CScha4
I am currently successfully using the Hand Tracker module in c# in order to get RGB view of the hand only. This works!
Now I need to be able to toggle between this, and a normal (but aligned) RGB image. However, when I retrieve the rgb image via sample.color, I seem to retrieve a "depth-limited" rgb image (i.e. a segmentation image) instead of the plain rgb camera stream.
I guess this is due to the enabled handconfiguration with segmentation. Is there a way to retrieve the plain RGB frames, i.e. before the depth-mapping happens? Thank you in advance.
Examplatory image of the captured rgb frame while pointing at a display:
MartyG
I am not the expert around here when it comes to programming color and depth streams (I'm sure he'll contribute advice when he sees this), but for now, I will offer a couple of links in the hope that they can get you started.
* Intel staffer Rick Blacker wrote an article on simple RGB streaming, with an attached code sample.
https://software.intel.com/en-us/articles/simple-rgb-streaming-with-the-intel-realsense-sdk https://software.intel.com/en-us/articles/simple-rgb-streaming-with-the-intel-realsense-sdk
* There is also a script that combines together RGB and depth streams into one. Whilst I know this is not your goal, you may be able to get some useful insights about precisely lining up two separate streams.
https://mtaulty.com/2015/04/16/m_15794/ https://mtaulty.com/2015/04/16/m_15794/
Hi Aeefire,
Thanks for your interest in the Intel® RealSense Platform.
Were you able to follow MartyG recommendations? Please let me know in order to assist you.
Have a nice day!
-Jose P.
